B
bachelor25
Well after much research and reading and probably too many questions, I finally got the information I was looking for in regards to lift options for my Explorer. So I grabbed my trusty can of penetrating spray and the neighbour's trolley jack and proceeded to try my mechanical luck. Well sure enough the adjuster bolts for the torsion bars are right there for easy access. I soaked them with the bolt freeing junk and laid into them with a socket wrench.
Well I'll be damned!! 2 honest inches of lift for the front end! I measured before and after on the same level surface (wheel lip to highest point of fender well) and improved from 11.25 to 13.25 inches! I took her out for a short jaunt to see how they would settle and at this point it looks like they've only backed down to 13 inches. Now it looks like some stupid pimp vehicle, with the front sitting 2-3 inches higher than the rear (rear leaves are already sagged a bit), but off to T&S Suspension in Langley for re-arched rear leafs and add-a-leaf to level her off. With an alignment I'm told the rear will cost me $300, taxes in ($225 for the leaf work, $35 for alignment + taxes). CDN $$ for all you US readers. ($300CDN = $200US)
Everything said, I feel much better knowing that I've got 2 more inches of clearance, and slightly improved approach and departure angles. Plus the coolness factor is very high. (Not many raised Explorers, especially late models, out there)
Thanks for everyone's input, suggestions, and concerns!! If anyone wants a run-through please email me, I'll explain how it's done. It's really very easy and anyone with limited tools and experience should have no problems.
Cheers,
Andrew B.
1996 Ford Explorer 4x4 (slightly modified)
BC, Canada
Cheers,
Andrew B.
BC, Canada
