Towing 98 Xploder 2-wd | Ford Explorer Forums
gbotay
CARSON, CA
98 XLT
Moving to FL. from CA.
Can I put a tow bar on the Xploder and tow it on all 4 wheels behind my Motorhome or should I get a flat car trlr?
I can't use a tow dolly because of the Xploder's weight.
Thanks for the help,
Gordon
If you remove the rear driveshaft, as I understand it when the rear wheels are moving when the truck is on or not the driftshaft still turns, and it still turns the transmission but without lubrication. Putting it in N maybe also work as well, I'm sure someone will chime in for sure.
Rear driveshaft needs to come off......otherwise you will fry the trans.
