quivver42
- September 23, 2014
- 2002 Ford Explorer
Hi, I'm new to this thread and an idiot with vehicles in general so if I'm posting this in the wrong place, then I apologize, please let me know and I'll take it down.
Here's what's going on.
I'm trying to solve a short in my 2002 Ford Explorer. A few weeks ago my battery started draining overnight. Using a multimeter, I found it was pulling over 2 amps while everything was shut off. After pulling fuses I found that removing F2.17 stopped the drain. This provides power for the windows, interior lights, and radio. I then found a short on the wires going to the light in the glove box. It is a black wire and a black/lt. blue wire. The short was NOT at the connector, so I tried, unsuccessfully, to trace it back to the CJB. So, I started pulling connectors from the CJB, I pulled the first one, located on the back side of the fusebox by the relays, and closest to the passenger seat. I put F2.17 back in and the drain was gone (~100mA or so). Progress!
However, now the interior lights don't work which I'm fine with but the A/C and gauge cluster are not working either, which is a problem. I also noticed that there is NOT a black/lt. blue wire at this connector. The wiring diagram shows the lights going to the fuse and relay, yet obviously it must branch off somewhere else, right? This seems like plenty of info to make locating this short "easy", but looking at the wiring diagrams has been completely useless and infuriating. I would be happy just knowing the pinout of the connector.
So, A perfect solution would be to fix the short. A good solution would be to disconnect the wire and never have a glovebox light. An acceptable solution would be for all my interior lights to be disabled, but everything else works.
Does anybody know how I could find the pinout of the connectors on the CJB, or better yet, does anyone know where the glovebox light wires actually go? I just don't get how the wiring diagrams show the lights going directly to F2.17 and a relay, but I pull that connector with different colored wires from the light wires and disconnect all the interior lights. Again, sorry if this isn't the right place to post but my hair is getting grayer every day that I think about this stupid problem. I'm also not wanting to take it in, I'd rather pull the fuse and just not have windows or a radio for a while. Thanks in advance for any additional information that any of you can provide to help me out.
