TomCat_Ford
- January 24, 2009
- 98 Explorer
Hey guys,
I'm in the process of trying to sort out my trailer light issues. I would like to be able to pull our boat (18ft Four Winns) without having to keep borrowing a tow vehicle. The factory 4-pin plug that was on there was shot. So I picked up a new 4-pin plug today (one with LEDs in it to let me know if it's working at the pin) and spliced that onto the factory connector's wires.
All of that works fine, my Ohm meter ohms out on each of the wires. Also, my running lights work just fine. The problem is that I have no signal lights and I have no brake light (which seems odd being that the running lights work). Only the LED for the running lights comes on when the lights are on. It's not the LEDs, I have 0 volts on the signal and brake when the running lights are off.
Any ideas as to why these aren't working? The 15amp fuse inside the driver's door is good. I'm testing all of this without the trailer hooked up; the boat is stored at the campsite where we do our boating...I'm 100 miles away.
