tranny issues? 00 5.0 | Page 2 | Ford Explorer Forums
Sounds like a converter issue to me.
yeah reading the stickies in the tranny section that is what i gathered.
stall rpm is too high...
Torque Converter Stall RPM Too High
Problem Solution
Aerated oil Put clear hose on thermal bypass outlet port. Run unit to check for bubbles in oil
Converter relief valve stuck open Do Converter-Out Pressure Test
Torque converter seal leakage Do Converter-Out Pressure Test
Torque converter not transferring power (bent fins, broken stator) Remove and inspect torque converter
ill be taking it in tomorrow morning.. not something i am comfortable messing with.
