Tranny Question | Ford Explorer Forums
Tranny Question
Offroad19
Ocean Springs,MS
93 Explorer EB
Is there any trannys out there that will bolt up to the stock 4.0 of my 93 that is better then the stock one? Also if not I tore mine up is there anything I can do to it to make it stronger?
I asked the exact same thing for my 92 and i found out that
A C5 with a c5 bellhousing, torque converter and flexplate will bolt up
A C4 with a C5 bellhousing , torque converter and flexplate will bolt up
A 700R gm tranny with aftermarket adapters from Advanced adapters will work but its more costly
If you want to know how to make it stronger you should check out the "My A4LD Rebuild Diary" Do a serch and you'll get tons of info
Also, i do believe the C4 and C5 are 3 speed trannys and dont have overdrive. The 700r has overdrive i think and the C5 is found in bronco 2's i think
Are there any rebuild kits that include everything like bands,bushings,modulator,servos,sprags and everything this else the rebuild kits come with.
will the C5 and C4 bolt up to the stock transfer case?
Ok i have read info from several different posts and if all was correct the C4 and C5 should bolt up to your stock transfer case
I really havent reserched enough to find out about the different rebuild kits that are out their. I think shooting a pm to Glacier991 would be a good idea because he seems to know a fair amount about the A4LD
Theirs a bit of info i gathered from asking about a junkyard C4/C5 tranny, May be useful to you, may not
http://www.explorerforum.com/forums/showthread.php?t=111643&highlight=junkyard+tranny
