Tranny question? | Ford Explorer Forums
Tranny question?
DonM
Ocean View, NJ
95 XLT
This may sound stupid, but im just trying to understand a few things alittle better! ;)
About a year ago, i had tranny problems in my 95 XLT, i believe it was the planetary gear?
Anyway, ive read lots of threads about how the Explorer trannys are very weak! So here is my question... what if any, are the main problems with the trannys? I know there are many gears and parts that make up a tranny, so is it the whole tranny that is weak? Or is it just a certain gear, or somthing?
Sorry if this is a stupid question, im just trying to learn.
Thanks
Don
Btw i have a list of all the parts and repairs to my tranny, if that may help me understand some things.
Here is the list of things that were done...
Gear-Trans FWD Ring
BRG-ASY-Trans FWD CL CARR
Retainer ring wireEXT 39 X2.4
Planet ASY-trans FWD
Gear-trans. Sun- FWD
Shell-trans input
Cylinder ASY- Trans FORW Clut
Plate- ASY Trans CL INT SPLIN
Plate- Trans CL EXT SPL
Plate- ASY Trans CL INT SPLINE
Case ASY Transmission
16 XT5 MERC 5
Drum & Clutch ASY- Trans Over
Band ASY Trans Reverse
Kit Oil pan screen & Gasket
Seal ASY - Rear Axle bearying OI
Lubricant- Hypoid Thermally STA
Additive Friction Modifier H
??? This may as well be in a Japenese. ;)
Don
Ok great! I'll go over there and see what i can find?
Anyone else have anything to add?
Don
I'd like to say that not all explorer trannys are weak, mine is 212k old and it's just now showing its age. I believe one problem that is seen with those trannys is that the overdrive may tend to quit on people. that's because it's a pretty massive gear (by that I mean that the gear ratio is pretty large) and some people use it all the time and put a lot of pressure on the gear. Other than that I haven't heard of that many real problems with the transmissions, it's just that some people may not be as fortunate as others. Not all trannys are supposed to last 200k+, I just got lucky. I just sounds like you had some bad luck with yours. It's not often that I've heard of planetary gears screwing up like that. weird.
I see, i didnt mean to say all Explorers have tranny problems... it just seems like quite a few have problems!!
Don
