ERIC
- July 2, 1999
- Wilmington, NC
- '96 XLT
The topic of the apparently short-lived EXP auto tranny has come up many times on this board, but I haven't ever seen a discussion by some of you gear heads (band heads?) regarding the best option for someone who is going to have to deal with a crapped out tranny.
I am specifically interested in the often short-lived auto tranny in the 4.0L. I have seen at least one reference here that it is "too weak" for the job. Whatever the case, there seem to a lot of them that begin to slip, especially when cold and in cold temperatures, around 100K miles.
The tranny in my '96 XLT has 126K on it. Over the past three winters, it has become increasingly slow to shift and lock up when first run in the morning. In fact, it is to the point now where it won't operate properly after being parked 5-8 hours in an ambient temperature of less than 60 degrees. At this point, a two mile drive usually brings it up to speed, so to speak. However, the handwriting is on the wall...this tranny isn't going to make it thru another winter.
My options are:
1) Let the Ford dealer slip in a factory rebuild at $2500 or so. (FWIW, my Taurus had a factory rebuild installed under warranty...it failed in 10K miles...2 weeks after the shortened warranty ran out...and Ford would not discuss a make good.)
2) Let AAMCO rebuild it (unknown cost). (After the Ford unit failed, AAMCO then installed a rebuilt in the Taurus and it was fine...but I only kept the car for 25K after the installation...not a real test.)
3) Let a local tranny shop rebuild it for $1075 plus up to $400 in "hard parts." (Several friends of mine who are car freaks...custom rods/classics/etc...are recommending a particular tranny shop they regularly use when rebuilding and repairing.)
Obviously, the local shop rebuild has a nice cost advantage. Also, the place gets recommended by some fairly demanding owners. I'm inclined to take this route.
However, before I make this decision, I'd be interested in any thoughts from those of you who actually know something about auto trannies...cause I sure don't!
My options are:
