White86Tercel
- September 13, 2008
- Kelowna
- 1998 Ford Explorer 5.0AWD
My grandpa gave me his 1983 Ranger 4x4 with a 2.8l engine, a C5 automatic tranny, and manual locking hubs.
Any suggestions?
- When I fire the truck up in the morning it works fine in reverse but won't move in drive (sometime it will move forward inch or two then stop moving).
- If I warm the truck up for 20 minutes, the truck drives great (I managed to drive the truck home 500K from my Grandpa's without any trouble).
- We left the truck idle for two weeks and noticed a small leak (maybe 1/8 of a cup) of tranny fluid comming down the passenger side of tranny.
- The tranny fluid/filter were changed about a month ago and my grandpa thinks the problem got a little worse after the change (it used to only take 10 minutes of warming up to drive).
- The tranny fluid has only being changed two or three times over the last 25 years / 16000KM
- I don't think the bands have ever been adjusted.
- The leak was noticed when the truck had sat for a week, the fluid level was normal and the lucas fluid hadn't been added yet.
- We tried adding the 1/2 Quart of Lucas Tranny additive (bringing the fluid level a little over max) and it seemed to help a little (the tranny seems to start going forward after a shorter warm up now).
- I get the same results in 2H, 4H, and 2L
- I get the same results in D,2, and 1.
- It looks like a small amount of tranny fluid is leaking out the bottom of the pan. I noticed this after driving 500KM with the tranny slightly over filled...
Any suggestions?
