trans slips when cold | Ford Explorer Forums
black crowe
louisville,ky
'92 EB
I have only noticed it when really cold out, after first startup. When warmed up it doesnt do it. Does anyone know reason why? Also, can this be a problem that can be fixed w/out buying new trans?(cant afford it!) Any help much appreciated. BTW- has anyone ever gone to amco or mr. trans and not been told they need a new one? Just curious..
Mine does the same thing. Where it has trouble shifting into 2nd when it's cold. But after about 1 or 2 minutes it's fine.
Assuming you have the A4LD here's what I've been told and read up on is that it could be a few different things. Starting with the easy and cheaper fixes first.
Possibly just needs a tranny flush. And I'm not talking about a quickie oil change place. They never do it right. You'll want to find a real tranny mechanic that will drop the pan and change the filter inside. The quick change places will just pump oil though for a few minutes. and charge you the same. Plus that's a good time to have him or you check for metal shavings or other problems. I would expect that to run around 80 or so.
I think anything else would require the tranny to be dropped. There is a oil sending unit that can get clogged an dirty. That sits on top of the tranny and's very hard to get to. But that little guy can get clogged and cause the problem. He will let oil go though and determine when the 1-2 shift happens. Then it get's clogged and the colder oil makes it hard for it to go though.
I've found around my neck of the woods that our trannys are they're bread-and-butter. So to say that you'll find an honest tranny guy to simply clean out a little do-dah thing in a few minutes isn't a real possibility.
Then the last thing I can think of is that it will need to be dropped and a complete rebuild done. Expensive stuff there. :confused:
Hope that helps and good luck!
One last thing that I've bought but have yet to install is a secondary transmission filter. Here's a very good thread on that. It helps to further filter the oil.
Dead Link Removed
My wife's car slipped when cold. Turned out it was low on ATF.
mine would have no drive when it was cold, would back up as nice as you please though, did a fluid and filter change it's good as new.
make sure it has enough ATF and if you do drain it all, make sure you replace it with the right grade.... oh... if you get a full tranny flush, have them pull off the pan and replace the filtering magnet in the bottom... you'll be suprised at what you find down there.
THANKS to all for advice. A lady at work was telling me today that she had exact same problem with her ranger. she had seals replaced(350.00) and that took care of it. I hope i get by that cheap!
Definitely start with the cheap fixes. My Aerostar had a similar problem, and low fluid was the cause. Read your manual for the warm-up procedure, and then check level. If you're lucky, it will cost a bottle of fluid. If that isn't it, then find a good tranny mechanic.
mine did the same thing for a while, I finally had to take it in, and it turned out to be a vacuum modulator gone bad in the tranny. ATF was getting past the modulator and being burned up in the engine. I had lost almost 2 quarts of ATF. Cost me 500 bucks for parts, labor, and tranny service, but it runs great now.:hammer: :hammer:
