rlhack
- August 17, 2004
- Corona, CA
- 1998 4 Dr, 4WD XLT
I have a 98 XLT 4x4, 92K miles. At about 88K, the notorious 6 blinks of the "4WDHi/4WDLo" lights and this fourm led me to replace the speed sensor (actually the dealer agreed with my initial diagnosis). Now, the 6 blinks have returned. I returned to the dealer thinking the speed sensor has once again failed. The dealer has come back saying that there are two other problems: (1)the "computer" in the transfer case is no longer communicating and needs to be replaced and (2) the shift motor needs replacing. Admittedly the vehicle is road driven 95+% of the time and I do not ever move from the "auto" setting. Hence, I would guess that the shift motor is not an issue since it probably has only moved twice in year I have had it. I find the computer issue also wierd since something is smart enough and communicating to the extent that the lights are blinking 6 times.
In my opinion, the dealer is trying to scam some more money from me (quoted about $900 for two issues) when I still suspect the speed sensor. I know shift motors fail but seems unlikely for a vehicle that is road driven and the shift motor is never called into play. I thought the 6 blinks was definitely the speed sensor fault but maybe it is a more general transfer case fault.
Does anyone have any experience or input on this issue? Is there any issue with not addressing this issue immediately (long term damage to the transfer case); it would seem the worse situation would be that the vehicle will not shift to 4WD hi if and when called for.
Thanks loads. Hopefully I can save some money!!
