Transmission acting up | Ford Explorer Forums
Georger252
Westminster, MD
04 EB
My 04 EX with 67K has for the last few days has started to shift rough and sometimes slip into the higher gears. I have noticed the trans downshift rough lately as well. This occurs when the vehicle is cold as well as warmed up. I would hope that the trans is not going to fail already with what I consider not so high mileage. I have seen other posts that suggest a "re-flash" of the transmission when others have had transmission issues. Is this a common problem for these transmissions? Any information would be appreciated. Thanks
Start with a fluid change (not a flush) if you haven't had it done in a while. If you have, then just check the level.
If you get it done at a dealer, then check into a flash upgrade also.
Mine has been doing the same crap. Not so bad last few months, but tonight, bad.
local dealers want a hundred bucks to flash the PCM.
-Shawn
the flash is delayed shifting,
But i don't want to bum you out, but mine acted funny just before it went at 50k, lost 3rd gear. . . .$1600 later its great.
