eclipse5302
- April 8, 2003
- Waukesha, WI
- 91 XL - 92 XLT
Well, I've just finished rebuilding and re-installing the A4LD in my 92 X, and everything is working great! Not too bad for my first A4LD rebuild...
Anyhow, I was curious about adjusting the vacuumm modulator and TV cable. The Transgo shift kit I used gave a suggestion about adjusting the TV cable, and I followed it as closely as possible. But I don't quite have that warm and fuzzy feeling about it. Does anyone else have a suggested method for adjusting the TV cable other than the old "pull it out all the way, and floor the gas to reset the position"?
I also put in an adjustable vac modulator. Its still set as I got it, and I know on the FWD trannies I've built I usually turn it in a turn or two to firm things up. Should I do the same with this transmission, or leave it?
TIA,
Jason
TIA,
Jason
