hellokw
- December 20, 2012
- 2000 Ford Explorer
I would like to know if it is possible to adjust the bands on a transmission in a 2000 ford explorer four wheel drive it has the sohc six cylinder and an automatic transmission. the symptoms it has are evident when you are accelerating and it is going to shift into third gear and if you push hard enough on the gas to make it down shift (the engine just revs) till you let off the gas then it will shift. Am I right to assume that it has something to do with the bands or is it something completely different
Ps. if you need more info on this vehicle I will do my best but cannot promise the world
