1996BLKBauer
- June 24, 2011
- McHenry, IL
- 1996 Eddie Bauer AWD V8
So my Explorer has had some transmission problems, or it seems that that the transmission is the problem. A delay in acceleration(which I think is a lag from the computer to the engine, because it is not like the transmission is slipping), and jerking(climbing in RPMs, and then slamming into gear) into 2nd or 3rd gear, and a clunking feeling randomly on downshifts. I am sort of worried here because one minute it works great, and then the next it has all the symptoms at once. Onto of that I am am a college student, and my funds for vehicle repair are low, to none. I am not entirely certain what transmission I really have, but I believe I have the one that is in my Specs sheet on the site here.
Enough rambling, I am contemplating, doing a change of the fluid, many people on here said that they did that with the transmission I have, or think I have, and that the problems have gone away. On the other hand all the older mechanics my dads know, have said to me not to change it because it will not move again. I have almost 162,x.. miles on it now, on what I assume is the stock fluid, not sure because I have only owned the truck for a year and a half. I also took a look at the fluid, and it was dark, nearly black, with a hint of red, it smelled bad, but not burnt, so hopefully that is a good sign.
So I am sort of at a standstill here, not sure on what to do, or even what brand of filter to go with, I am thinking WIX filter, when/if I get one. I would really would like some input here. I am also thinking of changing the transfer case fluid, before winter hits here, is it true that it takes ATF fluid?
