Sam 1122
- July 7, 2002
- iowa
- 95 XLT
95 XLT Explorer. I'm installing a B+M SuperCooler. The fitting that was with the kit will not work. The threads that screw into the radiator are the right size but it's not the proper type of fitting. I was hoping to install the fitting in the bottom hole of the radiator and connect the cooler hose to it and run the line to the one side of the cooler. I think I read somewhere where the fitting needs to be a compression fitting in order for it not to leak. All I need to know is what size and type of fitting(barb?) that I would need to have in order to install it and then connect the cooler hose to it. Thanks for your help!
