Truckinmario
- May 31, 2015
- Vienna WV
- 99 Explorer
Just bought a 99 explorer, with the SOHC and the 5r55e. I bought it with the PO stating that it has transmission issues. "Made a big clunk wouldn't go forward put it in reverse and parked it" When I picked it up today I put it in gear and it works in all gears. However it feels like its slipping in all gears, like it takes a lot of rpms to get it to go, and none of the gears will move under idle. all gears however will move the vehicle. The fluid level looks fine, smells clean, and looks pinkish like it should. I'm thinking torque converter. How about y'allls thoughts. One strange thing I found is that on the idiot gauges its not showing a lot of volts. Im assuming that since the 5r55e is computer controlled that could cause some issues. Any ideas?
