Transmission leak. | Ford Explorer Forums
Transmission leak.
robyrne
94 explorer
i have a 94 explorer and the transmission started to leak from the right (passenger) side and since all i can see is a round extrusion i need a picture of that side of the tranny and any suggestions on how to fix it thank you randy
Welcome to this forum! I've moved your thread into the transmission section. There are many places where fluid could leak (seals, hydraulic fittings, modulator, gaskets, etc). Clean the transmission, and place a cardboard under it. Let it sit for a few hours, then see which area of the cardboard has fluid. This will help you locate the area that is leaking.
i thought i made it clear that it was leaking from the right (passenger ) side at a protrusion that is made of plastic but i can't see it clearly so that is why i need a picture of that side randy
thank you for the picture i now know what i couldn't see and i now can look to see if i can replace the cover on the right fathest from the modulator randy
