TheJackal
- August 11, 2007
- Mandeville, LA
- 1999 Explorer XL 2WD
It's that time again. Yep, time to change the ol' transmission fluid in the '99 Ford Explorer 2WD. I've seen one method posted on here where you effectively "flush" out your trans. with two buckets and some hose; connect hoses to cooler in/out lines, put hoses in buckets, put required amount of ATF in the intake bucket, and let 'er rip. The issue I'm having with this is, I don't think that all of the fluid ends up circulating through the cooler, so you'll just end up with a mixture of old and new ATF. That being said, you don't get it all out with the drop & fill method either.
I've read that the above method isn't best for high-mileage transmissions, either. I've got 130,000 miles on the trans., and I know that places that have the expensive machines for this don't use them on transmissions with that many miles on them.
So, here's my question: Should I use the flush method, or simply drop & fill? (And I know if I choose the first option I'll still need to drop the pan to change the filter.)
Transmission fluid is a bit brown but has no strong odor or particulate matter.
Also, any suggestions on how to drop the pan without making a royal mess? I'd like to not get soaked in old ATF.
