evildrbug
- February 14, 2007
- Ohio
- 95 XLT
I have a strange problem that doesn't seem to quite match up to anything I've found searching here or elsewhere on the web. I have a 95 Explorer XLT with automatic and 4.0L, over 200 k miles. Fluid level is good, but it's probably due for change.
The problem is that occasionally, when i've driven at highway speeds for an hour or more nonstop, the engine will intermittently speed up by 300 - 500 RPM, and then return to "Normal" speed, getting more frequent if I continue at speed. The vehicle doesn't speed up, or slow down, the only way you would notice is by seeing the tach jump and hearing the engine speed up. If I get off the highway and shut it off for 5 - 10 minutes, it will stop, some times for 15 - 20 minutes, some times for good. It doesn't do it at all at lower speeds. Taking it out of OD at highway speed causes the engine to speed up by 800 - 1k RPM, so it doesn't seem to be intermittently downshifting.
Any idea what the problem could be, and what would be involved in fixing it, or getting it fixed? TIA.
Bill
Bill
