Transmission slipping in a 96 Explorer. | Ford Explorer Forums
cmills269
Lakeland,Florida
96 XLT
My 96 Explorer trans sometimes hard shift between 1st/2nd. Several days of hard shifting and then no problems, doesn't seem to be a pattern. the vehicle has over 200K odometer has not work in years. Not to good on the PM aspect, unknown last fluid and filter change. Fluid level is good no burned odor. No check engine or O D light.
welcome
If it has a (A4ld) trans Trans code "T", it has a vacuum modulator, controlling shift points, sticking or leaking diafragm, (trans oil at vac manifold)
