transmission slipping | Ford Explorer Forums
explorerguy94
albemarle nc
94 explorer xlt
I got a 94 XLT and the other day I noticed when it went in second gear it felt like it was dragging and the rpm went up high before it shift into gear and if I let off the gas just right it would go into gear fine. I checked the fluid the next day it was low so I added more in but it was still doing so I changed the filter and put in valvoline max life mercon fluid and lucas no slip but it didn't help. Its fine once it gets in gear but I have be real easy on it. Could it be a valve, vacuum, computer or something? Thanks.
my guess is something is hanging up in the VB....
How do I check that? Do you have a diagram? Thanks!!!
