Solved - Transmission won't shift from park with the engine on. | Ford Explorer Forums
Solved Transmission won't shift from park with the engine on.
Prefix for threads that contain problems that have been resolved, and there is an answer within the thread.
Malk67
Location
Salisbury
North Carolina
96 Aerostar XLT 3.0L
Well this is something new to me. With the vehicle running I can't get my transmission to shift out of park. It will however shift when the key is turned forward and NOT running. It will "full cycle" shift once I start her in neutral.
I'm thinking it may be the neurtral safety switch or another electrical component but I REALLY don't want to start dropping money into multiple components that aren't needed.
Any thoughts/sugestions?
I assume you are pressing the brake pedal when trying to shift, correct?
Yes I was.
just replaced the 8 pin switch and now it would seem that my "linkage" allignment is off, I have to manually move the lever.
And I also discovered that the brake lights are not working, gonna get a new switch and try that.
*grrrr*
the brake switch should fix it
Switch is good, just tested it with a multimeter. So now I'm gonna disconnect the brakelight "strobe", I'm thinking that's gone bad.
Update, removed the strobe switch and brake/shift issue solved. I'm hoping I've got the trans. shift in a proper position. If nothing else I'm carring a 7/8" socket on a ratchet with me tonight if I have to crawl underneath and "drop it" into position.
