nautique196
- April 13, 2010
Hi evryone, I'm working on a 2003 mountanieer with a V6 and auto trans.Trans code V(5r55s i believe)about 150k mi. I got the Check trans light flashing at me and scanned it. I found P0741 torque converter slipping/not engaging. I did alot of research and decided to replace to solenoid pack and the plate between the valvebody and transmission. I've heard that those plates will crack and cause weak pressure to the tcc. I went ahead and replaced it all last night, new filters and gaskets, filled with fliuid. and went to go drive it. Well i put it in reverse and backed out of the garage. When i went to shift to drive it made a loud clank. i went to give it some gas and it keeps going backwards! tried all gears 3,2,1. even in neutral it will drive backwards. I was careful not to mix anything up and everything installed smoothly. No leaks. I checked the part no. on the old solenoid pack and it ended with AF. I looked at the box and the new one(from ford) is an AG. Is this just an updated part or did i get the wrong Solenoids? Ive done plenty of valve bodys on other transmission and havent had a problem. Im stumped and have looked evrywhere. hopefully someone here can help. Thanks in Advance
