trany problem | Ford Explorer Forums
trany problem
BOBBY32
Delanson new york
2002 ford explorer
good after noon have a 2002 4.0 auto 4x4 need some help I have looked all over the net but people are not having the same problem as me my over drive light will flash and truck will not shift I turn truck of and back on all is good truck ***** like it should I also have the p01700 code but just got it I have a hard time believing my tranny is junk I saw that a Torque Converter will cause your od light to flash any help would be great
Glad it "***** like it should" for you after power-cycling. :D
P1700
Internal Component Failure, Direct One-Way Clutch Failure
Failed A Neutral Condition: FMEM Is Active;
No 1st, 3rd Or 4th Gear In Automatic Mode,
Other DTCs May Set
is that part of a rebuild kit ? sorry I took so long to answer need help asap transmission is deed now and I do have the 5r55w correct and what dose production DATE have to do with finding a tranny for my explorer?
Here is a link: https://www.etis.ford.com/home.do
Click on it, then click vehicle -- and you can put in your VIN number and it will give you lots of info on your exact vehicle. I know mine is an early production date 2002, and there seem to be some differences from the later production date vehicles
here is a link: https://www.etis.ford.com/home.do
click on it, then click vehicle -- and you can put in your vin number and it will give you lots of info on your exact vehicle. I know mine is an early production date 2002, and there seem to be some differences from the later production date vehicles
ty sir
