Solved - Trip 2 display | Ford Explorer Forums
Solved Trip 2 display
Post number 8 has been selected as best answered.
Prefix for threads that contain problems that have been resolved, and there is an answer within the thread.
griffisc
Greer, SC
2022 Explorer Limited
I purchased a 2022 Ford Explorer Limited a couple of months ago and can't find a Trip 2 option on the display options. I have search everywhere and can't find anything that really helps. Any suggestions?
My ST you have to select what screens you want to display and Trip1 and 2 are options in the select screen/display settings.
Thanks hbalek - When I scroll through my select screen settings I get: Calm - Fuel Economy - Trip 1 - Tire Pressure - Audio Source. No Trip 1. arggg
Welcome to the Forum. :wave:
According to your manual, you should have both Trip 1 and Trip 2 displays in the Trip Menu (page 117). Check the list on page 20.
Thanks Peter. When I scroll through my display options, Trip 2 is not there. Does a MyKey make any difference?
I don't think MyKey would make a difference but then I've never used that feature. Is MyKey activated on yours?
I just checked our 2020 ST. I could have sworn that Trip 2 was available from the info screen that shows MPG, time driven, etc. That screen shows "Trip 1" at the top. I just checked and I don't see Trip 2 anywhere.:dunno:
I just went and checked my Aviator and the Trip 2 screen did not display. However, it is there. I don't know if this was caused by the latest update or not. When I went into Settings, Trip 2 was not selected. In order to select it I had to unselect a current display as 6 is the max number that can be selected. I removed Calm Screen and then Trip 2 was able to be displayed.
The manual says some display features would not be seen if you don't have MyKey activated so I did. No Trip 2. Looks like MyKey just activates certain safety features only.
Hmmm. 🤔
Ok, FINALLY found the proper path of selecting stuff that showed Trip 2 as not being selected. So now it shows. Thanks for the help from everyone and being patient with me.😁
Can you share the ‘path’ as I just picked up a ‘23 Limited and also can’t find Trip 2. Thanks
See post #8. That is the way it worked on my 2023 Aviator.
THANKS. Was staring at me right in front of me and I didn't see it. Have to go to the "Screens" menu. Got rid of 'calm' as I'm not sure who likes to look at nothing 🤔
You can select Trip 2 by pressing tge Menu button on the steering wheel. Then "Select Screens" here is where you will find Trip 2
the Menu button on the steering wheel
The option is in the screen selections in the Main Menu.
Press the Menu button on steering wheel. Then scroll to the Select Screens. This is where you will find your screen options
The member you replied to was last seen here on May 20, 2024, so may no longer be following.
