shore_rider
- October 24, 2007
- nanaimo bc
- 93' sport
I have a 1993 ford explorer (pushrod) which currently isnt running due to two reasons.
1. clutch issues began once it hit -20C, it feels to me like the slave cylinder is the problem. Anyways, so one morning it seemed like the clutch froze to the flywheel, and since then i have to start it in gear and pump the clutch about 20 times to build enough pressure to disengage the clutch to change gears. I took a look under the truck..... looks like the slave is leaking a small amount (fluid on outside of transmission). So does this sound like the slave is gone? Does anyone know of a guide for replacing it? would I need to drop the transmission in order to get to it? is there anythign I can do to help the clutch in the cold (some kind of warmer for the fluid or something)?
2. The other problem is once it hit -25C the truck stopped starting. It would start fine until tuesday afternoon when I went to start it and all I could hear was a clicking (relay and solenoid it think) So I jumped it and all was fine. Then I get home and park it, decided to try to start it to see if the alternator charged the battery enough, nope just click.... click.... So I put a new battery in, it started. Then the next day i go to start it and the same problem again (but swapping batteries and jumping both do nothing now) So I jump under the truck and look, had someone crank it over while I hit the starter with a hammer, and sure enough it started. So the starter obviously needs replacing, but the strange thing is that when it started and was idling the in-dash voltage gauge and oil pressure gauge were going from normal to extreme (batt=low/oil p.=high) and the lights were dimming as well as the abs light coming on. So could the starter cause these voltage drops? any advice?
Thanks a lot and any kind of advice is awesome since my truck is dead right now. everything is greatly appreciated.
