Check the caliper pins to make sure they are sliding ok and that they have enough grease. If you are pulling hard to the left, then your right side front caliper is probably the culprit. I would check them all (front and rear) to be sure.
Bleeding the brakes is also a good idea.
Bad alignment can also cause pulling to one side, so if the brakes seem ok, I would have an alignment done next.
