Got a real big problem. wont start. Issue started late last night. was thought to be bad battery replaced battery and bad cables. tries to start now but just cranks. it's the 4x4 with v6. Need resolved asap as this is the only vehicle for my family!
THanks in advance, George
no start procedure:
1. Does "THEFT" blink rapidly with ignition key in Off, On or Start?
Yes: Verify key validity
Check Passive Anti-Theft System (PATS)
No: Go to next numbered step
2. Check fuel tank gauge reading. If fuel possibly contains water or condensation from cold add treatment to the tank.
3. Turn ignition key to On
Does "CHECK ENGINE" illuminate?
Yes: Go to next numbered step
No: Perform the PCM Power Procedure
4. Turn ignition key to Start
Does starter motor crank engine?
No: Perform Starter No crank procedure
5. Does "CHECK ENGINE" illuminate while engine cranks?
Yes: Check crankshaft position (CKP) sensor
6. Does fuel pump run?
No: Perform Fuel Pump Electrical Procedure
7. Check battery voltage
8. Perform TPS Test Procedure
9. Check ignition coils, plugs and wires. Some members have experienced ignition faults with Bosch platinum plugs.
10. Perform Fuel pressure test procedure
11. Check fuel injectors
12. Check compression
13. Check EGR system
14. Check engine coolant temperature (ECT) sensor if not a cold start
