Turn Signal Mount | Ford Explorer Forums
Turn Signal Mount
mwarren03
1999 Ford Explorer Sport
I had my 1999 Explorer Sport parked on the street and unfortunately it was hit (hit and run). I haven't had any success finding the mounting bracket for the passenger side turn signal. The turn signal just slides rights out without it and any replacement part just seems to be the signal itself. Any help?
If you open the flap above the parking lamp there are two phillips screws that hold the parking lamp in place. Those screws go through the mounting tabs on the parking lamps. These tabs get brittle with age and break. The screws and remnants of the tabs are probably still in place.
For mine I took a couple thin pieces of aluminum and epoxied them to the parking lamps to recreate the tabs. I drilled a hole for the screw and it fits like original. I did have to grind down the top of the rib to create a flat surface for the new aluminum tabs. I can get pictures this evening if needed.
