turn signals not working to good | Ford Explorer Forums
MountainMonkey
canada
93 xlt
s my turn signals arnt working correctly. the passenger side signals work fine but the driver side ones dont flash and just stay on while there engaged. any idea what could be causing this? and is it an easy fix? the front driverside headlight assembly is smashed up so maybe that has something to do with it?
If either the front or the rear turn signal bulb is not functioning/burned out then it will not flash.
Also check the flasher, and ground 103.
If you do a search for "turn signal stays on solid", you'll find this is a common issue and has been resolved in several threads.
For instance in this thread the ground 103 issue is explained by rwenzing.
