dr jazz
- February 9, 2002
- Maine
- '95 XLT
Hi,
I had a local U-haul intsall a t-cooler yesterday. Two questions for you-
They used the "regular duty" cooler, designed for towing loads up to 2500 lbs, instead of the "heavy duty" unit for reasons of space. They are the same width but the bigger one is about 4' longer. It looks to me, after the fact, that the bigger one might have been squeezed in there, and it is what I was originally quoted as being the usual for this vehicle. Do you think it is worth asking them to change it, given that I tow a 2600-2800 boat and trailer occasionally but not for long distances? When he decided on this one I figured really any cooler was better than none, so I went with it. Any thoughts?
He thought he was installing the cooler after the radiator cooler in the return line, but my "feel the pipe" test indicates it is in line before the radiator. From reading posts it seems most suggest after the rad. Does anybody think it makes any real difference?
By the way the guy did really clean work, using all brass fittings without having to cut the stock lines so it should be fairly easy to change. I'm pretty fussy about stuff, so I thought I'd get your opinions before deciding.
Thanks!
John
Thanks!
John
