umm wheres this line go? | Ford Explorer Forums
SwaintaN
Carey, Ohio (Georgia Grown)
93 XLT
Ok, so took wife to the pet store, spent alot of money, come walking out, noticed, WTF IS THAT?!?! a line hanging out under the truck that hooks to the axle on driver side?!? Where does that go????? More money to spend?? HELP SOON!!! thanks!!
This is what i saw
Close ups
(hose hooked into the axle behind the rear driver side tire)
Another close up
Help thanks!!
It is your axle vent tube. You can zip tie it higher up if you want to cross rivers/etc or to get it out of the way.
it's a vent tube, it hooks to the frame with a clip, up next to the top section of the rear shock. I just looked under my truck just to see where it went to, or didn't go to in this case.
shooooooo, i done thought i busted some major line, i was ready to crap my self, ok, ill crawl under tomorrow and just zip tie it up higher away from the ground. thank you!
you're welcome
When you do, make sure that there's a bend in it and the open end is facing down. The tube opening should be about an inch below the bend.
What does it do? Just help releases built-up air pressure from. Sorry for the Dume question and thread jack.
It's just an atmospheric vent to prevent the diff from building pressure as it heats during operation. If you don't put a bend in it with the open end facing downward, water from tire splash etc can enter. It'd take a lot, but it's a simple precaution.
