Ronin8002
- March 23, 2003
- Virginia
- 2008 XLT Ironman
Just finished installing my ASP underdrive crank pulley and Underdog performance underdrive water pump pulley. I also bought an overdrive alternator pulley but I haven't installed it yet. Anyway, I learned a number of things in the process so I thought I'd post them here for the benefit of anyone who was installing them on a 3d gen.
Pulling the clutch fan:
-I rented a clutch fan removal kit for this, however, the wrench that is supposed to fit around the fan nut itself was a bit too big. I used vice grips on the fan nut and put a cheater bar on the handle of the vice grips to break the fan nut loose. You could also use a large crescent wrench so you don't scratch up the surface of the fan nut.
Pulling the stock crank pulley:
-Nothing really 3d gen specific here. I didn't feel like removing my radiator just so I could use an impact gun so I bought a 20 inch breaker bar and used an impact socket and impact extension. I hooked up the breaker bar to the crank pulley bolt then braced the breaker bar against the top of the drivers' side frame rail. I then bumped the starter once and that loosened the bolt just fine. Another thing about pulling the crank pulley without removing your radiator is that you will have to cut about 1.5 inches or so off the center bolt of your crank pulley removal tool. I believe Aldive mentioned this in his writeup also...I also found it to be a PITA. Not really a dremel job...more of a die grinder job.
Installing the belt:
-It was recommended that I use a Goodyear Gatorback belt for this installation, part number 4060865 (86.5" long). I decided to try it, even though I didn't install the alternator pulley today. Well, turns out this belt was too large for the setup....every time I turned my A/C on the belt started screeching and wouldn't stop until I turned off the A/C. Sometimes it would even start screeching during a turn (I guess due to the increased load of the P/S pump) and would keep screeching as I drove down the road....not cool. If I had installed the Underdog Alt pulley (smaller than stock) it would have been even worse I think. I ended up putting the stock belt back on....I *think* it is 86.3" long. Anyway this fixed the problem from what I can tell. I may need to step down to an 86" or smaller belt when I install the Alt Pulley.
Edit: The stock Motorcraft belt (part # JK6-861BA) actually measures 86.125" So basically that's a tiny bit bigger than the equivalent Gatorback 4060860 or a Dayco 5060860 (both 86" even) The auto parts stores didn't have these in stock so the factory belt works for now.
Other impressions:
-No problems with alternator voltage once I got the belt problem worked out. I am seeing 13.8 volts at idle and 14.0 above 1000RPM with the A/C on or off. Not really sure I need the alt pulley so I'll just keep an eye on it for now and see.
-No problems with cooling either...normal range of 192-198 driving around town with A/C on or off. Ambient temps are in the mid 70's.
So far, seems to be a worthwhile mod. I think I felt a slight increase in power and I definitely made a noticeable increase in mileage driving around town (about 2-3 MPG from what I can see so far...based on the Scanguage II). I'll be making a longer highway trip tomorrow and will comment on my mileage from that. Before I installed the pullies I was just barely 25 MPG on the highway at about 67mph with no traffic.
I am leaving the clutch fan installed for now to see what kind of mileage I get over the next week or two. Later on I will install my Black Magic 150 electric fan and a Spal variable fan controller to see what that yields.
Other impressions:
