Uneven wear, front right tire | Ford Explorer Forums
mhallack
Rockland, Maine
94 XLT
I did a search for this problem, can't find anything. One problem I seem to have with my 94 is the front right tire will wear faster than the rest. Tire pressure is normal. It's wearing the most in the middle and outer edge of the tire. Inner edge seems ok. A few months ago I had replaced the rotor, calipers and and pads on that wheel due to the caliper stuck in the clamped position wearing the brake pad down to rivets and ruining the rotor. Before it was fixed that same side tire wore down faster too. The brakes on both sides are fine now, and I don't seem to have any alignment problems (Doesn't pull when you let go of the wheel) Can it be an alignment problem anyway? If not, any thoughts what could be happening? Thanks!!
Can be a camber problem,go ahead and have the alignment checked.It wouldn't necessarily pull with the camber off.:D
