Universal joint help | Ford Explorer Forums
norton155
niles il
97 xlt
I need to replace the U joints on my 4x4 97 XLT. I crawled under it today and noticed that I will probably need a special socket to break the bolts loose. Are they just standard 12pnt bolts? I tried searching for a write up but could not find anything. Thanks in advance.
I have both regular and ratcheting 12pt box wrenches. You don't think I'll need my impact gun to break them loose?
Any of you guys have a preference on the brand of U joints? Napa and Autozone both sell aftermarket ones with grease fittings. Do you I need anything heavier duty then those?
Thanks a lot Brook. I think I'm going with the ones from Napa with the grease fittings. Can I use the same grease in those as I've been using in my ball joints and tie rod ends?
