benwood
- February 19, 2007
- Seattle, WA
- 1991 XL Sport 4x4
Hello all,
Time I joined, my Explorer is getting old, a '91 sport, since it needs more coaxing nowadays, but not a lot (just 92k miles)
Today I was replacing the air cleaner and when I was removing the shroud over the Mass Air Flow sensor cable, I noticed a loose cable coming out of the back of the air filter housing. The cable's still attached to the air filter housing -- it's the other end that appears to have come out of a boot and after an hour of trying to find where it went, I gave up and took a couple photos hoping somebody else could steer me to the right area. The cable is the driver side of the two out the back -- the right one (on engine, left in my photo) is a vacuum hose, and the left one (right in my photo) is stiffish, black, and appears to be an electrical or heat conducting cable based on the exposed end that shows wound aluminum wire. Any ideas? I test drove with the cable not connected on the "other" end, and after a few miles, everything still seemed normal. I suspect this has some use though
Thanks for any help!!
Here's a couple pics, first the cable end:
And now the photo that shows the cable, with handy arrows. Note that I have the cable "on top" but I believe it wound around underneath the radiator hoses towards the front of the engine and somewhere near the bottom of the battery perhaps? It could also have wound back to the firewall, based on length...
