alohamonte
- October 4, 2007
- Glendale, AZ
- 1998 Explorer 4.0 4x4
I've been getting about 16 MPG on the last tank of gas, down from the normal 18-19... had some time today to look around under the hood... a new air filter was caked up in dry mud pretty good from a recent romp in the mud.
Replaced the filter easy enough, but there is a layer of mud dry at the bottom of the housing... I can 't figure out how to remove that housing so I can wash it out... any ideas?
I wanted to clean out the MAF to make there that wasnt dusty and I never realized that one of the torx screws has a coating of hard plastic melted over it... it's basically sealed. Anyone else have this? I can post a picture if that would help.
And no, no engine damage, the filter it its job and kept the bad stuff out. i checked the rest of the X out for trail wear and I also have some moisture in the rear diff. so that will need to be flushed.
