jon_s_brady
- August 17, 2008
- '05 XLT
I have an 05 Ford Explorer XLT with the 5R55S transmission. From what I can tell it is the 3.55 gear ratio (sticker on the door says "45"). I'm getting clunking - particularly when reversing out the driveway of a morning and what I think is slippage (car seems to rev a lot higher for given speed than before). That car has 146k on it now. I'm figuring I'm up for a new/re-conditioned transmission if I want to keep the car. Since it's in great condition otherwise it's worth the expense in my books.
The thing is...I want to tow a 4500 boat and trailer with the car. My reading of this and other forums leads me to think I need a 3.73 gear ratio with limited slip as it can handle up to about ~5500 lbs of trailer.
Does the 5R55S come in both 3.55 and 3.73LS? Or do I need a different model transmission? Are there any tricky problems in putting a different transmission in this vehicle? I'll probably do it myself with a re-conditioned transmission. I've re-built engines before and do most of my own maintenance including changing manual clutches but an auto transmission will be a first...
Advice is welcomed!
Advice is welcomed!
