martin123
- April 7, 2008
- Toronto
Hello
Done my lower ball joint. Started to do my upper control arm. Started soaking the 2 bolts for removal. Noticed that the bolt at the front of the control arm was broken. How important is this bolt? What does it do? What is it called, if I need to buy a new one? Also do I have to remove the old half still stuck in the SUV?
Thanks
Also about the lower ball joints I did not remove the caliper bracket or dust cover. Did not see the need and the job was still very easy.
Thanks
