tonymac97XL
- February 23, 2006
- Washington, PA
- '97 XL
Hey Guys,
I'm trying to replace the upper control arms on my 97 X, get the passenger side (adjustable one) done no problem, the driver's side, however, I've hit a glitch:
The bolts that hold the arm in place don't want to come out. There's a piece of plate steel that appears to be part of the head of the bolt (pressed or welded, I'm not sure.) Is that supposed to come off of the bolt? Because if it doesn't, I can't think of any way to remove that bolt without cutting. Before I start BFH-ing and using C-clamps, I wanted to know if that hunk of steel is seperate from the bolt, or if there's something I'm missing altogether.
(keep in mind this explorer has 138,000 on it, and I think this is the first time it's had the front suspension serviced (I bought it at 117k). Things are pretty rusty.
