Upper Control Arms | Ford Explorer Forums
Upper Control Arms
edcon1983
Emmaus PA
2001 Explorer Sport
Hi guys,
New here. Just bought a 2001 Sport 4wd. The truck is in need of upper control arms/ball joints. Through my research, I have discovered that there are two options for the arms. 1 piece or 2 piece. The issue I am having is that my drivers side arm is a 1 piece and the passenger side is the 2 piece. This is confusing to me. I've been looking at other Sports in the junkyard, and I haven't seen any others that have 2 different styles. My question is; Is this normal? Is it possible that one side was converted for some reason? Any help with this is appreciated as I am driving the Explorer to South Dakota from Pennsylvania in less than 2 weeks, and I want to take care of this. Thank you in advance.
Thanks guys! That info was very helpful. I ordered a pair of one piece control arms. Hopefully my olds ones come off relatively easy.
Just did both of mine , stuck with the 1 piece and 2 piece, hardest part was getting that camber bolt out, took me 1 hr for the first side, my tip if the bolts are rusted seized , use a air hammer and hit the alignment washer to break the seal and rotate that bolt.
Will work better and just push thos lines to the far left without breaking them.
I paid 40$ a Side from Amazon for MOOG
Car hits bumps like a dream now :)
GL!
I like the 2 piece on the PS side. Takes about 7 minutes for a ball joint change. 2 18mm bolts the cross bolt and it falls out...No playing around with the upper bolts... Drivers side is a nightmare. Also, don't try to move the brake line to slide the bolt out on drivers side. If it's ugly it will leak.
1pc upper A arm
I like the ideal of new bushing on the 1pc A Arm.
