V8 AWD XFER CASE FLUID | Ford Explorer Forums
DanEB
Southern, MA
97 Limited AWD V8
Hi All:
Can someone please verify that the transfer case on a 97 Limited AWD V8 uses Mercon ATF? Thanks!
-Dan
1997 Explorer Limited V8 AWD
2002 VW Passat
your owners manual should say, but the transfer case in my 97 V-6 OHV calls for Dexron III Mercon ATF. I would suspect yours is the same. If you want to though you can replace it with Mercon V or a synthetic ATF. It is all up to you.
