F14CRAZY
To the flo...
- October 31, 2002
- Dimondale, Michigan
- '92 GT, '93 Limited
This is what I always figured...
Take a transfer case, power steering system, manual transmission, and drive axles. They do wear. All of these things listed above have gears of some sort. These gears working on each other for X amount of time wears them down. Wear is taking metal off metal. The little bits (varying in size) are flying around. A lot of it is picked up by magnets, but otherwise, they just keep flying around. While flying around, they get between the gears. Instead of metal on oil, it's metal to metal, causing more wear. The rate of wear will exponentially increase until something blows up OR the oil is changed. When it's changed, all this grit goes away.
Then you mix in water from condensation. A small amount of water is going to get in any lubricated system, and don't let anyone tell you any different. Water and metal don't go together well. This rust will form in places like the top of the component housing. Then that can fall back into the oil and gears below causing more heck.
I have seen this all happen. When I bought my XL in Pennsylvania to drive back to Michigan, I drove it less than a mile to the nearest Iffy Lube to have most all fluids changed in it. I had the guy that dumped the transmission fluid (manual) wipe his glove on my finger and I closely inspected it. Sure enough, the oil contained metal grit. It's obvious to see. Do you expect this oil to effectively lubricate the transmission when it's operating at 70 mph? Is it going to keep the gears reasonably cool and keep the wear rate low, relating to the exponential theory above? I hope as heck not. This goes for transfer cases and axles. When you have it pumped, ask them for a finger sample and hold it to the light.
Power steering is a bit different. You can't exactly change it, but what I've done is initially suck out the resevoir with a turkey baster and refil it with the proper fluid (for my Ex, it's type F ATF). Then go drive it for a day, and repeat this a few times for a few days. It'll turn clean. Then I suck it out and replace the resevoir contents at about every oil change.
Now, I cannot say for automatic transmissions. I don't think I am qualified. But this thread did start out with transfer cases. I assure you that there are no detrimental effects of changing the oil in power steering systems, manual transmissions, transfer cases, and axles, if done properly.
