Well you guys were right on the money about the vacum leak,I discovered it today while instaling my new Bosch 4+,It was right were you said on the driverside of the intake their is this fiting that four vacum lines plug into one is the pcv valve and the other is the brake booster.My problem is that on that fitting I found that on the back of the piece there are places for two vacum lines and mine is missing the inner most line.It is just gone I looked around the best I could and I cant find it.If anyone has the same model as me and can look and see wear this line goes maybe I can trace wear mine went.I think it may have fallen behind the engine somewhere,the only way I could get a better look would be to pull the upper manifold and I would like to avoid that if possible.So if someone could check thiers then I would know wear to look.Any ideas what would cause this and my truck seems to be running lean at least thats what my code scanner said.
91 Eddie Buar
192,000 miles
91 Eddie Buar
192,000 miles
