vacuum cap 1997 mountaineer? | Ford Explorer Forums
rblancrt
97 Mountaineer
Hi,
I had a backfire on startup and now have a vacuum leak. I know because this happened to me once before. I would rather not pay to have it fixed this time if I can fix it myself.
I have read on the web about vacuum trees and that on startup a backfire can blow out one of these little rubber vacuum caps. I have seen the vacuum caps at O'Reillys, but I don't know where they go.
Is there a vacuum tree on the 97 Mountaineer, but if so where is it? I have tried to find it but no luck.
Any help would be appreciated greatly.
Thanks,
rblancrt
Found where the vacuum cap was missing from, problem solved.
rblancrt
I am now very curious as to why this connection is there in the first place. I'm not a car guy so will try my best to explain where it is.
On second thought I don't think I can. It comes down from underneath the engine, to the left of the master cylinder and underneath. It seems to be a metal tube, comes down and then elbows towards the front of the truck.
As far as I know there is nothing that connects to it and it is now capped with a vacumm cap.
If anything I said makes sense to you do you know what this connections if for, why it's there in the first place?
Thanks,
rblancrt
