vacuum hose - HELP | Ford Explorer Forums
vacuum hose - HELP
habhead
Help! A vacuum hose has come off on my 92 4.0L V6 and I can't find the beginning or end. There is a fitting on the drivers side of the engine, near the firewall where 6 or 7 hoses connect. The one I have lost is that nearest the engine on the firewall side. Can someone with the same engine pop your hood and tell me where it is supposed to run to?
Thanks!
Not all the lines are used. Depends on what accessories you have. You may have just lost the cap, not an entire hose.
its easy to fix
my hose did that too ad i just re connected the hose to the valve that points to the driverthat still left and open hol which i concluded that i just needed a valve cap. i think you should try putting the a cap on the vacuum valve and the see what happens. If you have a hose that is not connected to any valves then connect it to one (it shouldnt matter which one on the vacuum). let me know what happens!! good luck!!
