NintendoKD
- October 27, 2011
- Franklin Co V.A "the moonshine capitol of the world"
- 1998sploderxlt RWD 4.0OHC
Still having problems getting my sploder runnin right.I have replaced the fuel pump, which was going bad, and fuel filter. I have also replaced all plugs and wires. I have cleaned the maf, and the entire throttle body, as well as the TPS. When I changed the pump there was a significant change in engine behavior, for the better, however, it is still running rich and has very inconsistant throttle response, the shifts are slow or late, and it is not throwing a code. I did notice that when I manually rev it, with the hood open, it makes a peculiar hiss sound. I tried spraying wd-40 around the area where the hiss is heard "wd-40 will burn faster than gas and the engine will revv when sucked into the vacuum leak" to no avail. I am assuming that at this point that the upper plenum gasket needs to be replaced at 240,000? or possibly a vacuum leak somewhere else that I am not aware of? I wanted to see if anyone else has had this issue. The throttle response is spotty running better at some times than others, all issues fixing themselves, then going back to running like crap and idleing like poo. I have to say I am stumped, usually intermittent problems can be led to an electrical issue, so I will go through every fuse tomorrow.
