CypherSTL
- April 22, 2009
- St. Louis, MO
- 2000 Sport
Symptoms:
So, after getting the check engine codes I pretty much have 5 codes I'm dealing with. After looking around under the hood I have noticed that the DPFE/"EGR Valve Pressure Feedback Sensor"(NAPA) does need to get replaced. Looking more, the orange VAC Line is cracked and broke off in various places along the route of the line.
My main problem is the vac line has completely broken in places so I'm not sure where its supossed to run to. Any insight?
Also, I have a few questions. The DPFE Seneor, as you can tell is broke, would it also possibly set off the code for a possibly bad EGR Valve? I'm thinking yes, but correct me if I'm wrong.
My next question, is could all that being wrong also cause the Large EVAP Leak?
- P0171
- P0174
- Possbile Bad EGR Valve
- Bad DPFE Sensor
- Large EVAP Leak
