Jag
- February 15, 2001
- Omaha, Nebraska
- 2002 XLT Sport
I recently had the transmission on my '92 worked on, in part to replace a defective vacuum diaphragm. The engine was sucking ATF up and burning it via the vacuum lines. I was losing about 1 quart of ATF a month.
To make a long story short, as a result, the vacuum lines that are connected to the vacuum tee on the rear of the intake manifold are swollen and fit rather loosely due to extended contact with the ATF.
I can replace some, but he plastic ones that have a rubber elbow attached to them may prove a little more difficult. Are these rubber elbows replaceable (they don't look like they can be removed from the plastic line) or are these a "buy at your dealer only"?
